HVAC Control Connector or Extention Cable
The_Mountain
Cow Hampshire
Where would you put it?
And your best bet is probably just to pick up an extra plug connector from a yard somewhere (should be the same for any GM truck with the same HVAC panel), and some wire, and make the extender yourself.
twinmill28
Spilled Milk
Not sure if that's a component specific connector or not, but I recently discovered Del City for all of my auto electrical needs https://www.delcity.net/
If it's not a component specific connector (just for the ac), you might be able to find male and female connectors (I think GM uses Weather Pack connectors) and then build your own harness.
Like Mountain said, you could pull a connector from a wrecking yard, but that will only give you half of what you need. I'd prefer to build a new harness to the length you need with all new stuff.
Good luck!
