Hypertech programmer
Mb30sdl
Hamster that pokes Bears
Raleigh area NC
So to correct my MPH discrepancy I got Hypertech speedo calibrator. After updating and programming it I had H2 go possessed at ~60mph. It shifted down, doors locked/unlocked and truck was behaving like it was dying.
ill call them Monday but has any one experienced that sort of thing?
Chook
Brisbane (Australia)
No , but I have a hypertech & know you can use a upload function
I would recommend you disconnect it, connect the programmer to your PC & upload your file for them to investigate ( I did his when VIN not recognized they were great)
Once you have uploaded to Hypertech via your PC Reintstall the Hypertech in your vehicle & you can tell it to reset to factory settings. (This was one of the great advantages why I bought this programmer)
When you reset to factory tune all should be working fine.
Once you confirm it is working fine in factory tune you can reconnect the Tuner to your PC & check to see if there I an updated tune available (Someone else may have found the fault also & they have a patch already available). If there are no updates then wait for Hypertech to email you in reply to your upload with the fix.
Mb30sdl
Raleigh area NC
Yes when I insalled factory tune back truck runs great, so guess there is some glitch. On tune mode I don't realy need it, so I just got speedo calibration pac.
ill call them today and will see if they can figure it out. I need them to do 5.38 tune too, their tune goes down to 5.13 only.
Mb30sdl
Raleigh area NC
Well, problem is resolved. Looks like programmer needs to read within +/-3mph from actual speed, if speed is greater (5+ mph in my case) computer goes berserk. 5,38 gearing is not available in this application so I had to play around with 5,13 gear and change tire size. Magic tire size was 34".
Now all is well.
