ISO h3 engine wiring harness
Steeltats
Kansas
Well, I’ve replaced pretty much everything you can replace including the PCM and I still keep getting a misfire and I don’t know of anything else other than it should be something with the wiring harness so I am looking to see if anybody has a wiring harness for sale might get the 37 with the automatic 2007 thanks.
speedy
Sir Welds a Lot
Dayton NV. Battle Born!!
No luck finding the harness.
Have you done a compression test?
Split the fuse block and check for corrosion?
Is it a random miss fire or the same cylinder?
Because it has to asked. Stock battery clamps😁
