H3slate
Brush raked
- Tualatin, Oregon
I have had a K&N cold air intake for a few years now and I have been pretty happy with it. The big drawback to me is the shield they send you to protect your filter from the engine bay. It leaves a lot to be desired.
There is plenty of dirt and water that gets in that area, as well as gaps that left me wanting something better.
Now I know that there is a product out there that utilizes the stock air box,:shifty: Air Doc, but I wasn't ready to fork out more money for my intake. Besides I still had the stock air box laying around and already had a perfectly good intake tube.
So I decided to see if I could keep the K&N intake and get the benefits of a sealed box for the filter. So, I started cutting.
I guess there is no turning back now.
Previously I had tried to eyeball to see if it would work, and you just didn't know for sure either way. I thought that I would have to modify the outlet hole to adjust for the more severe bend of the K&N tube. Once I had the hole cut I pieced everything together. It was a tight fit and all connections had to be made at the same time. But, it worked!! The hole was the perfect size for the tube, and there was room in the air box for the filter.
To try to make things easier to fit together, I cut 1 1/2 in. off the end of the intake tube. This would allow some more room in the air box to fit the filter. I also did some trimming to the ribs on the inside of the airbox to adjust for the new position of the filter in the box.
I reused some of the trim pieces from the old shield to help clean up the new air box hole and hopefully make for a tighter fit.
