First of all, greetings from Slovenia! Not a natural habitat of any Hummer, so support at local mechanical shops is virtually nonexistent. I've recently bought a 2006 H3, 3.5 i5, VIN 5GTDN136968246413. Not sure about the package, as it has heated leather seats (which i think are part of a lux package) and rear locker, which i thought are telltale sign of adventure package.
My problem is with the offroad ability/behaviour. While the rear locker works fine, i thought the traction controlled brakes apply brakes to the front spinning wheel, transfering torque to the wheel with grip. In some moderate offroading i did in the previous days i figured out the front wheel keeps spinning, without any torque transferered to the wheel on the ground.
I've done more tests today. It turns out, in some positions while in 4Low and rear locked, NONE of the front wheels are turning while both the back ones are spinning.
If i understand this correctly, 4LOW = middle differential locked = 50/50 front/rear distribution, so at least one of the front wheels should spin at all times, is that correct?
If that is the case, what can be the problem? In some wheel positions one or both of the front wheels spin, but in some positions i've caught the back two spinning and front two only twitching.
Initially i thought it might only be a traction control problem, now with observing a situation where none of the front wheels had any torque, i am not so sure anymore.
There are no messages pointing to the faulty TCS, stability is turned off as i shift into 4LOW. No dash messages pointing to any system, lights indicate successful engagement of 4High locked, next 4low and Rear locked.
I've tried searching the forums for some conclusive information on the topic, but were unable to find any, so any and all help would be much appreciated!
