I installed led headlights turn signals and fog lights. The turn signal bulbs require resistors which I have two slow down the blinker to a normal rate. Has anyone else installed led (switchback) turns signals? And also installed the resistors? I am trying to figure out which wires to tap so I can install my resistors correctly. If I am not mistaken one end of the resistor taps into the ground the other into the blinker wire if I am not mistaken. Could be wrong. For those that are unfamiliar with these bulbs when in running mode the bulbs stay on a 6k white once either blinker or hazards are turned on they flash from white to bright yellow. Thanks for any help in advance
