Well, I guess I should have listened to that old "stitch in time ..." maxim. I didn't, I ignored that occasional rattle coming from my H3's factory clearance lamps, and one end tore off at highway speed. Good that I have a sunroof. I didn't want to tear it the rest of the way off on the shoulder, didn't have tools with me to remove it by the side of the interstate, so drove home with my son and I taking turns holding the loose end from ripping free by reaching through the sunroof.
Got home, and, as I had feared, had a combination of sources of failure. Some of the torx screws were loose, some of the plastic mount from the bar had apparently torn free or broken previously (I suspect during a 3rd party windshield repair some time ago), so I was not going to add a couple of washers and bolt it back down.
Here's what it looks like removed:
I've been kicking around some ideas and have been enjoying some of the clever LED light bar ideas that I've seen in these forums. Looking for some feedback on what I have in mind.
First - the problem - the fastener system GM used is lousy - the threaded bases in the roof sheet metal break free and spin with the screws. I had to pinch two of them with a needle nose plier while I broke the screw free.
The solution - what do you think about a tiny tack weld to hold the base to the sheet metal where they broke loose?
Second - the opportunity - instead of putting the clearance lights back up there, I'm thinking about using those six threaded mounting holes to mount a low-profile LED bar. My thought is to fabricate a bracket that bolts to the six locations used by the clearance lamp plastic bar. Then put the LED bar in the bracket. I'd use the existing wiring - just add a switch and a relay. Then could turn on the LED bar with a dash switch when the lights are on.
Here are the factory mounting holes:
Here's where the factory wiring runs:
Any suggestions for the LED bar? Do you think the amp draw would be significantly higher than the five clearance lamps, requiring stouter wiring? Any suggested brands?
Thanks for any help!
