crank
The Master Blaster!
- Victoria, TX
Hey all. I've been working on this starter problem lately and have come across another problem.
For all of you that haven't been following the saga of crank's starter, this is what I'm doing....
I am taking out the original 97 H1 Wagon starter and replacing it with a aftermarket starter that will fit and run with this engine. I want to fix the original starter and keep it as a spare. Use the aftermarket starter to get me up and running ASAP. The aftermarket starter is a Ultima #03-0447 from O'Reilly Auto. It has worked on other H1's in the past by members in one of the forums. The problem I'm seeing is:
Taking out the old starter is a real bitch! There is a bracket in the front of the starter that I just can't get to laying ion my back. Is there a better way to get to that bracket? Is there a special tool to get to that front bracket? It's very tight in there and I'm on my back.
The aftermarket starter has a different layout for the wires and connections. It looks like I would need to change the terminals on the wires and figure out a way to stretch the wires/cables to fit. Not a direct replacement. Is there a better aftermarket replacement?
Another non related problem, I found a exhaust leak coming out on the passenger side of the H1. It's hard to see but it looks like a clamp is loose or something wrong between the manifold and exhaust pipe. I can feel the blast from it with the hood up. I don't smell anything in the cab though so it's not bad. Is there a better way to get to that? Did I mention it is TIGHT in there?
Any way, if anyone could shed some light on the starter replacement, I would greatly appreciate it.
