Motor mounts and crossmember bushing
yellowh3
The 3 is at the HUMMER dealer today. The cable that connects the interior door handle to the door latch broke. I had to put the window down and open the door from the outside to get out.:no:
I mentioned the "clunk" when shifting from reverse to drive also when I dropped it off.
They just called and said they are replacing the motor mounts and the trans cross-member bushing and the door latch under warranty.:thumbsup
I would upgrade to the PCF crossmember bushing if you off road or not. It will give you a piece of mind...
