Need Help locating a part that is used on the electrical connections throughout the H3 engine bay. I've included a pic. Thank you for any/all help...:thumbs:
Chris
Can you post a close-up pic? If it's what I think it is, it is called a TPA. I need a close-up pic of the unplugged connector as well, to make sure I steer you to the proper part.
Ahh, OK. It's a CPA, not a TPA. Again, if you take a pic of your plug I can confirm it for you, but as far as I know ALL GM MAF sensors use the same 5 pin Delphi GT-150 connector. So, yes, that CPA should work fine.
