No ground plane cb antenna range
southernhummerguy
Columbia, SC
I recently installed the Firestik 4' NGP antenna on the front driver's side fender (actually it's exactly where the pointless "GM" emblem used to be located), and I was wondering how much of a range I can expect? The antenna stands just around the preferred 2/3's above the roof and given that it's a NGP setup, I expect to lose a little performance. Also, since it's on the front fender, will that affect the strength of the incoming signal based on direction, i.e. will I receive a better signal from people in front of me or behind me? If anyone could satisfy my curiosity I would greatly appreciate it :)! Thanks!
Have you tuned your antenna yet with an SWR meter? That's the first step before anything else, including using the radio.
It has always been my understanding that only with an antenna that uses the metal on the vehicle for a ground plane that the longest plane across the vehicle is the strongest signal. With a NGP like used in marine applications on fiberglass boats it is considered to radiate in a circle around the ant. Non directional. I have also found that on boats placing a SS plate at the base helps radiation. I have even placed a plate at the top of a sailboat mast to help the CB performance but generally use VHF in that application. Placed at the top of a 30 foot + mast gets you to the line of sight horizon at about 25 miles.
I can remember when it was"the thing", to mount a 102 inch whip on the rear pass side of a metal vehicle so you could radiate towards the front driver's side across the longest part of the vehicle so you could reach out to on coming traffic, good buddy!:giggle:
southernhummerguy
Columbia, SC
Yea, I've set the SWR around 1.1 for my low channels and about 1.3 for my high channels (mainly since I rarely use the high ones). I always keep a little portable meter in the glove compartment to check it every now and then. Here's a site that can explain all the parts a little more in depth. http://www.truckers-store.com/store...Kit-Featuring-Molded-Side-Mount_40491594.html.
There isn't anything wrong with the system or anything. I was just curious as to how far I could expect to receive and transmit a signal :)
