H3 North style Hummer h3 modified for off-road. Russia, Kamchatka.
What temps are you currently seeing? There are many different temp ranges for sensors, if its too high the coolant will heat up alot before fan goes on, if too low the fans will stay on all the time trying to drop the temp
Spal: (185 ON, 165 OFF)
http://www.jegs.com/i/SPAL/063/185TS/10002/-1
Spal: ( 195 ON, 175 OFF)
http://www.jegs.com/i/SPAL/063/195TS/10002/-1
You will also need an adapter to fit the sensor into the engine head:
https://www.amazon.com/dp/B015NG418C/ref=cm_sw_r_cp_apa_XzjbAbRWCBMSA
Whatever fan you get, buy a good relay and fuse. The fan will switch on/off many times and this is hard on the relays.
