DaWgPoUnD
- South Carolina
2008 H3X
Changed the oil/filter today in my H3 and drained a little more than 5 qts out (truck on ramps so maybe left some old in?) Anyway, put 6 qts in of which added the last 3/4 of a qt after checking stick and looked about 1 qt low. After letting is sit for a while checked stick again and it looks to be about 1/4 qt over fill (above the full mark). Is there an "over fill" limit or such that if you over fill to a limit that will put to much pressure on seals? I am curious before I over react and pull the plug and drain some of it back out?
Thoughts?
Thanks in advance.
Thoughts?
Thanks in advance.
