Humvdood
- Fort Worth
I tboned a lady when north texas had some ice storms last month.
Totalled her ford ranger but all it did to mine was crack the grill and break my turn signal off of the headlight housing.
I hate fake chrome and was planning on getting the grill painted factory black anyway but my regular paint and body guy said he wouldn't touch it unless I removed all the fake chrome.
I went ahead and plastic welded the grill where it was shattered and cracked using steel wire mesh half way through removing the chrome - wish I would've waited on the welding since it would've made removing the chrome foil so much easier.
You can sand this stuff off with 40 grit sand paper but you're going to blow through about $50 worth of paper doing that and you're going to risk losing the ridges and curves as you try to remove it.
I got most of it off with a razor blade and a pair of pliers.
but it did'd hit me until near the end that hydrochloric acid will take that stuff off without eating the plastic - you'd need some type of dip tank - I used a storage tub and dipped the side in that I hadn't plastic welded and it came out super clean. If I'd done the whole thing though, it would've eaten that steal wire mesh from my plastic welding.
I just painted it with bedliner for now cause I got tired of looking at my H3 without a nose.
