S
SedonaBound
Has anyone found a decent iPhone app to use with a Bluetooth OBD reader? Looking for one specific to GM that reads more than generic CEL codes and does resets.
I use the bafx, its $24 and works greatDashCommand in the AppStore gets pretty good ratings. I did some research on it a few months back and thought it seemed legit. I lost interest after I saw the Bluetooth OBDII readers were $100 bucks tho.
Do you already have a Bluetooth OBDII reader? If so, which one did you go with?
Just a note, for iPhone/iOS you generally can't use a generic BT adapter unless your phone is jailbroken. iOS is very closed and many of the generic OBD adapters aren't 'authorized' - that's why you'll spend $100 for an adapter that is compatible for an iPhone. I briefly used Dashcommand on my jailbroken iPod, but found it wasn't as nice as Torque on Android.
Also, a few more comments on the cheap BT adapters (I use 2 different brands on 2 different cars):
- Refresh rate on the cheaper adapters is generally OK, but if you are pulling a lot of data (lots of gauges in your dashboard), it will probably slow things down.
- The chearper BT adapters don't always read 'extended' PIDs. Some may work great, others not so. Of my 2 adapters, one consistently reads H3 transmission temp, the other does not (Torque allows you to pull in GM extended PIDs).
- They won't always read every vehicle. I have a buddy with a 2002 4Runner...neither of my gauges will read his OBD, but they do read my other friend's '99 Chevy pickup.
- They won't always shut off when the vehicle shuts off or when your phone leaves BT area...this can be a serious issue if you don't drive your vehicle every day. If I forget to unplug my adapter and let the truck sit for a week, it will (and has) drained the battery. USUALLY, they will shut down when they aren't connected to BT, but sometimes they just decide to stay on and it can really mess up your day
- Android (and Torque) work great, much more of an open platform for this
I've used my cheapo BT adapters for years. The biggest frustration I have is the occasional 'stay on' issue - so much so I'm soon going to be buying the $100 adapter that has auto-shut off. The extra bandwidth (faster refresh) is nice, but not enough to justify the 4x the cost - but running my battery down is well worth the $$.
This is what I'll be buying when I get around to it:
http://www.scantool.net/obdlink-mx.html
And if you just want a code reader, this is what I use when my BT adapters don't work. I've had this for almost 10 years and it's never failed to read a check-engine light...
http://www.amazon.com/gp/product/B0007LEG2K/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Hi evldave,
mind telling me which scanner has the transmission temp available? I'm currently running a bullydog and it doesnt have the function, so going to move it over to my pickup but want to purchase the correct thing this time
The reader I'm using is no longer on Amazon, but my order history calls it 'Soliport ELM 327' - I think it's a crapshoot - just buy a cheap OBD reader for $15 and see if it worksI can almost guarantee it will work if you buy the nicer one, but the other cheap china ones are a shoot-and-hope deal. Good luck
Hehe. Thanks for the feedback. Think i would rather buy a decent one from the start then having to wait 4 to 6 weeks for delivery before i can test [emoji78]. Then i start wondering if a scanguage 2 wont be a better bet than the mx scanner. Mmmmmm choices choices [emoji33]The reader I'm using is no longer on Amazon, but my order history calls it 'Soliport ELM 327' - I think it's a crapshoot - just buy a cheap OBD reader for $15 and see if it worksI can almost guarantee it will work if you buy the nicer one, but the other cheap china ones are a shoot-and-hope deal. Good luck
Oooh. Now thats something i havent thaught about [emoji48] [emoji48]For the record, I run both! I normally have the ScanGuage plugged in but I like to run Torque and use the Track Recorder so I can see how my truck runs in videos later.
is there much of a difference between using scan guage and a bluetooth phone reader? I got a windows phone app and I ordered a reader. I was going to get a scanguage, but that seems redundant now. I'll post up how it works if anyone is interested.
I'm still kicking this around. Since Bluetooth scanners don't work with Apple phone iOS my only option for using Dash Command is a WiFi OBD scanner. I was amazed that they can make and sell a scanner with its own built-in wifi hot spot for under $30. Has anyone tried this? Suggested models?
Not cheap, but about as good as you can get...and it runs wifi, so compatible with iOS
https://www.scantool.net/obdlink-mxwf.html
I still haven't found scanner software that actually has enhanced GM PID's. some, like the scantool say they can read them, but if the software doesn't have them it's a moot point. I've been chasing an ABS issue for a while, but can't find any software to read the codes.
The ScanGauge II is a good choice since it does have the caapability to be programmed. However, finding the codes that you want can be a task.
