ADOR
- Las Vegas, NV
Hey guys. Can someone please let me know if I am getting this right about my tow rating and the weight I can safely tow with my H2.
8,600 lbs. – Gross Vehicle Weight Rating (GVWR - H2)
-7,440 lbs. – H2 with full tank of gas
1,160 lbs. – MAXIMUM available for driver + passengers + cargo (Is this correct???)
13,500 lbs. – Gross Combined Weight Rating (GCWR)
-8,600 lbs. – Gross Vehicle Weight Rating (GVWR - H2)
4,900 lbs. – MAXIMUM available for Trailer + Trailer Cargo (Is this correct???)
-4,020 lbs. – Travel Trailer DRY weight
880 lbs.– MAXIMUM available Cargo + Water for Trailer (Is this correct???)
700 lbs. – MAXIMUM Tongue weight with Weight Distribution Hitch (WDH) (Trailer Tongue Weight SHOULD NOT exceed 700lbs???)
Our Travel Trailer Dry weight is 4,020 lbs dry. I have 2 propane tanks and 2 batteries in the front. There will be 3 adults and 2 children riding in the H2 (approx. 600lbs combined weight. Some clothes and food. Not planning on driving with 50 gallons of water in the trailer Maybe 10 gallons max. I have taken the trailer twice to Mt. Zion from Las Vegas. When on flat land, engine and transmission temps are OK. But when we start o go uphill, the engine temp starts to go up. Normally, it is pointed at "half". I have to go easy on the gas dropping to speed to about 30mph. When I step on the gas, the engine temp stars to go up.
We are planning to drive to East Coast and back this summer. I am worried about using the H2 for the summer trip. So here are my questions:
1. Did I get the above numbers right?
2. If yes, and decide to use the H2 for the summer road trip, anything I can do to avoid burning my engine and tranny? (I heard about the external tranny cooler. How about the engine temp?)
3. Should I replace the hoses, spark plugs, etc.?)
4. What else should or can I do to avoid any mechanical troubles while on the road?
My H2 now has 32K miles. Tranny oil was changed about 8K miles ago with Royal Purple, added bigger tranny pan. Front/Rear Differential oil change with Roy Purple gear oil about 4K miles ago. It has a Rancho lift kit, 38" tires, 4.88 gears.
Your opinion/suggestions will be greatly appreciated.
