southernhummerguy
- Columbia, SC
Okay, so I searched the all mighty interweb and basically found nothing that addresses how to fix my problem. I have the monsoon sound system as well as an aftermarket sub-woofer and amp. I wired the remote "on" wire for the amp to the "on" wire in the head unit. This was fine and dandy until my battery started dying out within a year of replacing it (so it's definitely not the battery). My problem is that the radio stays on even after turning the ignition off, thus causing the amp and sub-woofer to continue draining the battery. I was hoping somebody could provide an alternative wire I could attach it to, :huh
r even better, a way to have the radio turn off when the ignition turns off. Thanks for the help!
PS. I disconnected the power to the amp, and it's been turning over fine ever since.
