Plugs and wires
glpd74
Wondering if you guys have an opinion on plugs and wires. I do have long tube headers that are not wrapped so is the increased heat something I should be worried about or should I just run stock wires and 41-110 plugs. Also when I look at plugs it tells me that they are not for my truck but I see other people are using them in their h2. Any insight would be appreciated.
TJ
Unless you have significant engine mods you probably won't see a benefit from moving away from OEM and could even have drawbacks.
Spark plugs, stock ones. As far as plug wires, I’d go aftermarket high temp, but also put some shields near the headers. I run shorties and have burned the wires first time around with them.
glpd74
Ok thank you guys for the insight, I really appreciate it. I’ll stick with ac delco non iridium stock plugs and look for some extra temp wires and some heat wrap.
TJ
