- Scottsdale
This procedure is essentially the same for the 3.5, 3.7 and 5.3, though I've been told the 5.3 does not have the slip shroud on the fan shroud, and that the cooling fan must be removed. Note that pictures from two different radiators are used in this post.
Ugliness, and only 18 month old OEM radiator
- Remove skid front splash shield
- Drain Radiator
- Using adjustable pliers or similar, loosen clamp on lower radiator hose and move backwards on hose
- Pull hose off of lower radiator opening and drain coolant into a bucket
- Remove radiator cap for faster draining
- Please note that in the picture below the transmission cooling line fittings are fully removed. Do NOT do this to your new radiator as you may not be able to put it back together. That transmission cooler is "floating" in there and you may not be able to line it up properly. We were just playing with it. 2nd picture shows how radiator should look upon removal.
- Unclip transmission cooling lines (automatic trans only)
- Pull back small black plastic cap on transmission cooling lines
- Using a small pick or similar, remove spring clip from transmission cooling lines
- Pull lines out of fitting. The large fitting with the nut should remain in the radiator
- Allow transmission fluid to drain
- Do NOT remove fitting as shown in picture. This is for illustrative purposes only. You might not be able to reattach this fitting to the trans cooler if you fully remove the fitting like in the picture below.
- Remove top radiator hose using same procedure as bottom hose removal
- Remove fan shroud
- Grab slip shroud knob located halfway down on passenger side
- Rotate it around 90 degrees, grab second knob, rotate another 90 degrees
- Squeeze clips on either side of fan shroud
- Tug shroud upwards and out of the truck
- Remove top bolt and bracket and foam, if so equipped
- Detach a/c condenser from radiator
- Tilt radiator backwards, lifting radiator up a bit if necessary
- 10 mm bolts, one on each side of condenser, facing the front of the truck
- Pull condenser upwards about 3/4" to lift it from bottom brackets on the radiator
- Remove radiator
- Detach front diff breather hose from the right side of the vehicle
- Detach coolant overflow hose from cap and brackets
- Pull radiator up and out of the vehicle
- Installation
- Reverse above procedures
- We were required to pull out the small nuts used for the a/c condenser and move them from the old radiator to the new one.
- If you are installing an external transmission cooler (or you have a manual and you got a similar radiator), do not touch the two transmission cooling line fittings. Those must not be touched to ensure the integrity of the radiator. No coolant will leak if you do not use these for your transmission.
- Filling coolant
- 50/50 mix of Dexcool and distilled water
- Fill radiator until full
- Fill overflow tank until full to "Cold Fill" line
- Leave radiator cap off
- Start truck and check for leaks
- Add coolant to radiator, add coolant as necessary
- When truck reaches operating temp, the thermostat will open and the coolant level will drop. Add coolant mix to compensate.
- When full, shut off truck and replace cap
- Top off transmission fluid as needed
- Time: 1.5 hours+. Alldata time is 2 hours.
- Capacities and specs:
- Cooling system
- Dexcool, 50/50 with distilled water
- 10 qt capacity. I drained about 7 qts, but needed about 9 to fill it, including the reservoir which had been low due to the leaking of the existing radiator
- Transmission
- Dexron VI
- 1st install we drained less than 1/2 quart
- 2nd install we drained about 3 quarts, as it kept coming from cooling lines since we weren't working very quickly
- Cooling system
