D
Deleted member 7876
Hey all, I looked for this and couldn't come up with anything so maybe someone here could help. Here goes, I recently purchased an '06 H3 Adv and had to replace a bunch of suspension parts, OK, almost all suspension parts. But since doing the rear leaf springs, shackles, and the upper bushings I have had a clunking noise/feeling underneath. I attribute this to the bushing in the frame for the upper shackle. I see that, on both sides, they slide back and forth in the frame. Are they suppose to do that? Call it ignorance but since I had a rough time getting the old ones out(using air chisel) and having to press the new ones in I assume they shouldn't be moving at all. Is this correct, or am I completely wrong? I took it to the dealer and they said the passenger side was dry, needed lube and that the bolt wasn't as tight as it should, so they lubed and tightened. Now I know It was torqued to the correct specs when I did them but could have come loose I'm sure. It stopped making the clunking noise/feel turning left but now does it turning right and backing up. Should I lube the driver side and re-tighten the bolt, or maybe do something else? This is my only experience with leaf springs, I've only dealt with coils. Thanks!
