So for the last couple months I have had a problem with my rear suspension on the right side. Every bump, it dramatically jumps, makes a load bang, and feels like the tires is hitting the wheel well, or the axle is hitting the bump stop. The ride on the truck is horrible and almost unbearable. At high speeds it causes the rear end to move on the truck. So I thought it was my shocks, and I recently put new blisteins with extended shackles, and the problem is still there. It has to be either the leaf spring or the leaf spring bushing. If I need to get a new leaf spring, should I buy oem, aftermarket, or have a shop make me one. I do want to do a spring over in the future. Also with the extended shackles, at full articulation,they become extremely tight, and it looks like my brakes lines will rip out. Does anybody know when to buy extended break lines? Thanks!
