Well, the title pretty much says it all: The right rear lower ball joint seems to be leaking an oily fluid. I thought ball joints were lubed with grease, not with oil?
since it is leaking could it be condensation, etc that could have got into a crack in the boot causing the grease to leak out more like fluid than grease? and could it be from the hub and not the balljoint?
