bajamcguide
- Utah
Trying to figure out the low? rough idle on my 06 H3, with the I5 3.5 with about 85,000 miles
Little history, purchased new from Southbay Hummer in 06, at 17,000 miles the dealer replace the cylinder head
all good till about 70,000 miles, when I saw blue/white smoke at start up after sitting for few hours at work, no CEL, but the motor would idle too slow and almost die at stop lights.
Removed and cleaned the throttle body and cleaned the MAF sensor, and the motor ran fine for about 2 weeks, Then the motor started to idle rough, I replaced all the spark plugs, and noticed that 2 of the plugs
were wet.
Back to dealer,they did a leak down test and found 2 cylinders bad,I had to fight them to get the price down to $1200 dollars to replace the cylinder head.
after 1 week I picked up my hummer,now on its third cylinder head, drove the car of the lot and had the exact same problem, low rough idle..retured to the dealer immediately to show the service manager the problem.
He said he didn't know what was wrong, but he was sure they needed to replace the head based on the leak down test. All the techs were gone till Monday, so he told me to come back on Monday, and they would do some diagnostic test to find the problem.
I have lost faith in that dealer, So I took the Hummer to Tustin Hummer and explained the problem. They told me the factory recommended that they disconnect the after market radio, and re flash the computer.
so when I picked up my Hummer the radio was connected and the motor was a little smoother, and the idle was at about 700 RPM's
fast forward 6 months and 5,000 miles and the motor is back to slow( 600 RPM) and shaking.
I am now living in Utah, and I am trying to fix this myself.
so far I have changed out the following. the MAF, all the spark plugs, the cam position sensors, the cam timing actuator, I replaced the #1 coil ( also moved the other known good coil packs) ran about 3 bottles of
injector cleaner.added Seafoam to a tank of gas.
Anyone have any more Ideas?
were wet.
