- Tardville
It doesn't get much easier. Here's everything you need, minus shocks & brakelines....
I bought this axle awhile back, from a guy that was upgrading to a Dana 60 in his full-size Blazer (trail rig only). It was completely rebuilt, and he ran it on the trail for a total of three 1-day excursions...the third trip which resulted in a broken u-joint on the passenger-side. This also screwed up the outer chromoly shaft. I replaced the u-joint on that side with a new Spicer one, and also swapped the mangled outer shaft for a used GM one from my stockpile. I swapped the drivers-side outer shaft also, just so they matched. This was an 8-lug, 3/4-ton axle with Corp 10b knuckles...all of which has been replaced with Dana flat-tops and 6-lug hubs. It now has chromo inner shafts and Spicer outer shafts. I bought it simply because its already set-up for an H3...4.56 gears and an E-locker. Its in fantastic shape, and it would be perfect for somebody looking for a budget SAS.
SPECS...
AXLE:
GM 3/4-ton Corp 10 bolt. Large tube/low pinion
Eaton E-locker
Yukon 4.56 gears (no re-gear required for 5-cylinders!!)
Stock GM cover
Stock Spicer yoke
Fresh diff bearings (under 100 miles)
THORparts 3-link H3 brackets, fully welded (lower links, shocks, springs, upper link tower, and track-bar)
Yukon Chromoly inner shafts - 30 spline
Stock Spicer outer shafts - 19 spline
Fresh Moog ball joints
New Spicer u-joint on passenger side
Dana 44 flat-top knuckles - milled, drilled, & tapped
Stock Steering arm studs, cones, & nuts
THORparts ABS hubs and caliper mounts - 6 lug with metric studs
New Timken hub-bearings (GM large)
Stock Spicer spindles (GM large)
Used Warn lock-outs
Fresh hub seals & spindle seals
SUSPENSION:
THORparts frame plates
THORparts adjustable coil buckets & (4) capture plates
Ballistic Fab adjustable shock towers
Super lift JK +6" springs
THORparts link bars (2" x .250" wall DOM), pre-welded
Ballistic Fab creeper joints & bushings on each link (with jam nuts)
Ruffstuff lower frame link mounts & upper frame mount
Ballistic Fab track-bar mount (inboard)
Track bar (1.5" x .250" wall DOM), cut & welded by installer
Heim joints on track bar (with weld bungs & jam nuts)
All hardware
STEERING:
Nissan Xterra box, rebuilt & ported by WTO *
Nissan Xterra pitman arm, re-tapered for 1-ton GM DRE
Billet passenger-side crossover steering arm
Tie rod (1.5" x .250" wall DOM), pre-welded
GM 1-ton TREs
Drag link (1.5" x .250" wall DOM), cut & welded by installer
GM 1-ton DREs (with weld bungs & jam nuts)
Hydraulic hoses to/from box
Sleeves for box mount, cut & welded by installer
Adapter fittings for GM power-steering pump to hydraulic hoses
*Ram assist available for $250 extra (includes ram, hoses, brackets & tie-rod clamp).
SHOCKS, BUMPSTOPS, & BRAKE LINES NOT INCLUDED! (Must be sized after installation)
REAR LIFT NOT INCLUDED! (SOA with stock leafs is recommended)
REQUIRES YOUR H3 CALIPERS, ROTORS, AND ABS SENSORS!
$4700.00
I have many more similar axles on deck (all Dana 44s), and I will be selling them off throughout this year. Prices vary depending on the build.
SPECS...
AXLE:
Eaton E-locker
Stock GM cover
Stock Spicer yoke
Used Warn lock-outs
SUSPENSION:
All hardware
STEERING:
GM 1-ton TREs
$4700.00
