One more tip that isn't so obvious (until its too late). Make sure to use your emergency brake if you park your H3 with stuff disconnected....or with both front wheels off the ground. The "PARK" gear will not do anything in this state. This is because "PARK" merely locks the front and rear output shafts together. Because the shafts normally turn in opposite directions...when you lock them together, the wheels on the pavement are the only thing that keeps the vehicle from moving. It doesn't actually lock the rear driveshaft in place like a normal 2wd car. Instead the rubber on the pavement becomes the actual lock. The fact that the front tires cannot roll in the same direction as the rear tires is the only thing that creates "PARK". Once you separate the tires from the pavement...you have no PARK anymore. This is especially important to know when jacking up an H3...ALWAYS CHALK THE WHEELS because "PARK" will be disabled as soon as the rubber leaves the pavement.
If you pick up either end of an H3...it is free to roll, even in PARK!
If you disconnect either driveshaft on an H3...it is free to roll, even in PARK!
So be aware if you unload it on a sloping parking lot. You will not have PARK with a driveshaft disconnected or with the front wheels on the dolly.
