Self Activating Seat Heaters
Portager
Silverado
I think I could install a second screw next to the seat heater switch and solve the problem, but Tustin Hummer said there wasn't enough room. I think I'll try a second screw and if that doesn't work I'll try the Dremmel.
Sent from my Galaxy Nexus using Tapatalk 2
I've heard of others doing the Dremel solution with success and then you don't have a bunch of exposed screws.
therick04pp
Massachusetts
The auto turn ON of the seat is cause by the plastic trim where the switch is. When you sit it push the plastic trim down and turn ON the switch. to Solve the problem you have to screw the trim into the metal frame in order to make it fixed. and here is where the screw goes. Passenger side View attachment 1949 Driver Side View attachment 1950 GM has a bulletin on this. After I mentionned it to the tech, he came back with it and he applied the screws where it was mentionned on the bulletin. No more heating seat automatically now. ;) hope this help with your problem.
Regards
Arch
It worked great. Took me 3 minutes to correct that issue...lol Thanks
H32NV
Golden, CO
will they honor the bulletin if I am outside of my bumper to bumper warranty? I still have powertrain warranty but i bet that doesnt apply here
SC_Hummer_Guy
Mr. Sexy Sugar Britches
North Charleston, SC; Angel Fire, NM
Wow I seriously was like some of y'all an thought this was rare enough that it was just me! Well now I know my A$$ isn't as fat as I thought an it's not completely my fault! Gonna have the stealership fix this next time cuz it sucks having this happen and I forget about it in this 103* heat here in SC.
