07Custom
- Albuquerque, New Mexico
So....
As you all know I have a d44 SAS H3. When I got it, it was in pretty rough shape. I've since made some great progress and it's been a very reliable and safe vehicle.
I had lots of dash lights, ABS, Stability, etc. I installed CJs ABS kit and now have active anti-lock brakes. That light turned off immediately upon installing the kit.
The stability light never turned off.
About a year ago, an airbag light came one. I didn't know what it was and all of the fuses looked great. I just bought a OBD code reader capable of reading and resetting ABS and SRS codes.
Last night I was able to erase and reset the service stab sys light and warning. I tested the button and was able to manually turn the stability system on and off. But today after driving about 5 minutes it turned back on.
I was never able to erase the airbag light, but I did pull the bcm code of B0026 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open.
I cannot reset this light. I've checked the under seat connections and everything else I could think of. A lot of other forums have linked this back to the "clock Spring" behind the steering wheel. Our trucks don't have a true clock spring, but I'm thinking it might be the same thing.
Does anyone know if the stability light and the airbag light can be related, and if it's possibly caused by a bad "clock spring"?
