rsm688
- mississippi
Okay guys well I have some slackslop/play in my steering. I can turn the wheel about an inch in either direction before it starts moving the tires. I have a brand new front suspension/tires/outer tie rod ends/intermediate steering shaft as well as an aftermarket steering rack mount bracket and new rack bushings on the driver side as well. So I can instantly narrow it down to the steering rack, inner tie rod ends (which felt a little loose) or upper steering shaft (unlikely). I have an 06 H3 with 97k miles that I bought with some worn out 35s on it.
Inner tie rods are gonna be around $70, I can get a Detroit axle rebuilt rack with new inner tie rods and lifetime warranty for around $200 shipped, I would probably go with the 16mm replacement so I would have to buy some new outer tie rod ends as well so around $275 total plus alignment.It's obviously more of a PITA to replace the rack but that's what I am leaning towards. I have no separation in my rack that I can see and it's not leaking any.
Any thoughts/suggestions?
Also, if I go with a new rack and go with the 16mm one, is it the 2007-2010 models that use the 16mm tie rod ends? I saw MOOG has two outers, one for the 2006 (ES800763) and one for the 2007-2010 (ES800762) so I am guessing they are the 16mm ones?
Thanks,
Spencer
Thanks,
Spencer
