So this happened when I got back from vacation
Vdawg1115
Oakland, CA
So I just got back from vacation today and I noticed the front passenger tire was flat. It was expected I guess, had a very slow leak just before I left. Tried starting her up after a little over 2 weeks and nothing. But the worse part is the key won't come out of the ignition now. Tried jumpstarting and it didn't help. But now the emergency lights flash in the dash. I press and depress the emergency light button but it doesn't do anything. It is only flashing in the dash, none of the external turn signals are actually flashing. What is going on?
Glad you got it fixed. Sometimes the battery just needs to be charged a bit longer if fully discharged.
You can charge the battery to get the key to release, or if you are on flat ground, put it in N and roll it a few inches then put it back in P and pull the key.... I didn't intend to rhyme BTW
