Stuck in trac lock
Yimmortal
Moab
2002 h1. Wont come out of trac lock. Works fine in low range and then when I put it back into high it won’t come out if trac lock. If I go backwards in a figure 8 it will come out eventually but it’s getting progressively worse. Anyone know what I need to do to solve this?
LagunaH1
Idaho
I'm no that familiar with the later model year H1's. Is track lock a differential lock? If it is, and based on what you describe, I'd suggest you have the diff inspected. It should engage and disengage pretty easily.
