- Scottsdale
When's the next time your going to Moab? I left a tie rod puller in Neos shed that I modified to work on my H3. Figured he'd have more use for it down there.
I took one if these. http://www.autozone.com/autozone/accessories/OEM-Tie-rod-puller/_/N-264w?itemIdentifier=555631_0_0_
Cut the bolt back to the threads.
Ground the feet a little thinner and angled so you could use a hammer to tap it in. Just don't take too much off the feet.
It worked fine way back when I went from 14mm to 16mm rods.
