Timing chain and GM rant...
Guess what, on the H3 you have to also remove the front axle (to remove the oil pan), so those on the C/C needs to stop bitching. :gaah:
You will still need to remove the axle to get to the oil pan!
Mr_Rich
Yucaipa & Santa Maria
I've pulled engines for lesser reasons and I'd definitely pull this one if it was mine. I'd also get the proper tool to hold the cams; it doesn't cost much. It sure is a good reason for an LS swap; especially when you're talking a $4K repair.
