Tire & Wheel Fitment?
OneRoad
USA
Hi all, need help to make sure this and wheel combo will fit on a 2007 Hummer H3 without any suspension/lift kit changes or cause any issues with inner sidewall spacing. Losing my mind with the calculations!!
Wheels:
DUB Push S110, Size: 24x9.5, Offset: 30mm, Backspace: 6.43", Bolt Pattern: 6x139.7 Hub: 87.1mm
Tires:
NITTO TERRA Grappler P305/35R24
Will these fit?
My inspiration for the look...
Wrangler sitting on 24x9.5 DUB S110s with Toyo Open Country MT 37x13.5x24 tires
Zoro is right on the Hub size. The bolt pattern is 6x5.5
The offset of this wheel puts the center of the tire out 8mm over stock. You need to make sure that the wider wheels (3" wider) wont interfere on the inside with the suspension. You will need half the extra width (1.5") of clearance at the wheel. Keep in mind the wider tires will also require clearance.
OneRoad
USA
Thanks guys. Really helpful!! Decided to go with 20" wheels on 35" tires with the right offset and backspacing. 24s were too big for the Hummer on second thought
