H3T Tool Box
cdarveaux
Colorado Springs, CO
What is a good toolbox to use for the T? I don't mean the Hummer ones, they rusted all my tools and spare parts. I'm looking for one that you would usually see on like an F-150 or a Silverado. Any suggestions? Thanks.
I use Hardigg (Pelican) cases for my gear. These are military surplus units...water-tight, light-weight, impact-proof, etc. I've not seen any that are specifically made for "tools" but, they come in all sorts of sizes. I have paid $10-$40 for them, and I've never been disappointed. Here's a quick ebay search that shows the range of sizes, however these prices are absurd...
http://www.ebay.com/sch/i.html?_sacat=0&_nkw=hardigg+case&_frs=1
cdarveaux
Oh those are nice I love those!
Sent from my SAMSUNG-SM-N900A using Tapatalk
Airborne
Just a regular dude
Utah
I highly recommend those cases. A few made it back with me from Afghanistan and they are built tough. I like that they have pressure release valves. At least the 2 that I have do.
I have some of the military cases and the one with my spares rides around in the bed of the H1 24/7. Never had a water infiltration problem.
2010H3TAlpha
Issaquah, WA
Split it open and silicon the two pieces that meet.
Finally had time to take mine apart today and I plan to silicon the two pieces together after it dries (gave it a good wash with Simple Green). It sure doesn't look like it would leak between the two pieces because of the gap fitting that joins them...but I did notice a couple spots that looked weak...
Any other areas you know of where these leak? I will also test spray it with water tomorrow to double check the hatch seals.
I just picked up this plastic locking sealed tool box to try and install on some slides to store bunch of tools and other items that I have been keeping in the cab of the T since taking off the snugtop (didn't want people to take me sh!t)
Eventually it will hold a second battery, ARB twin compressor.
The unit only fits front to back, just a few inches too waive to fit side to side and basically is the length of the box and half the width I'll post up details as the project develops as I am sure there are aome technical over laps
2010H3TAlpha
Issaquah, WA
Took my factory Hummer toolbox apart and I think I found the culprit. There is a corner where the two pieces meet that was not aligned during assembly and when the bolts were torqued it left a gap and bent part of the plastic. I filled it with silicone and it is setting now. Rain test scheduled for tomorrow :)
SolidusJ
FT. Carson, CO
Trust me, this was my box.
2010H3TAlpha
Issaquah, WA
Okay I think I am pretty close to waterproof with the stock box now. The other major areas of concern are the bolt holes in the back where the box attaches to the truck. I put waterproof tape on the inside and outside of each hole and I added a seal on the outside (just the one seal washer on the inside doesn't seem to do the job). Dumped a ton of water on the box and still 100% dry inside!
it is supposed to rain tomorrow so I will report back with my findings :)
