Tough Stuff EZ-FLIP LICENSE PLATE BRACKET
crank
The Master Blaster!
Victoria, TX
For all of us that Ned to have two tags on our rigs and a winch and fairlead on the front, there is this bracket called EZ-Flip plate bracket. Has anyone tried the EZ-Flip license plate bracket?
I just installed that bad boy on my H1 and it works great. Stays put without falling off and flips out of the way when you need to use the winch.
crank
The Master Blaster!
Victoria, TX
Yep, that's what I have. The snap rings hold it nice and not worried about it flying off. I tried a plate that just snapped on but was worried someone would grab and run.
ReconH3
Guardian Angel
Raleigh, NC
does anyone make a bracket for a hawse fairlead ?
I just loosen it slightly slip the lip of the license plate between the fairlead and the winch mount. When you tighten it, it holds it in place very firmly. The opposite end of the license plate I use double side tape to stop it from vibrating.
"Ex Umbris Venimus"
Sent from my iPhone
Portager
Silverado
I just mounted mine above the Hawse Fairlead, against the bumper. It is low enough that it doesn't block airflow into the grille and it is out of the way of the winch. It is also somewhat protected, since it is behind the Hawse Fairlead.
