Traction Control Failed?
Cliff
Oregon
I've recently had the "traction control failed" notification come up on my 2006 H3 and was wondering if anyone else have encountered this same problem. I'm currently away from home (truck driver) and have not been able to run any codes or check fuses. It occurred after installing a double din stereo and I'm hoping it was just a coincidence it showed up then and I didn't somehow screw up the switch or anything. Switch still shows it going on and off when pressed, also transfercase shifts fine so I don't think its the switch, maybe a sensor?
Any help would be much appreciated and might help me track down the problem quicker when I return home.
Cliff
Oregon
Also, I've still got an extended bumper to bumper warranty for 2 more years so if it ends up being too big of
a PITA or expensive I can just take it to a shop. I'm gonna be checking to see if the warranty will cover fixing the 2 broken exhaust manifold bolts and tire pressure sensor failure anyway. I don't think the heads been replaced and its an 06' with 84,000 miles so there's a chance that will go soon. Maybe I can vet lucky and have that replaced as well.
HummDinger
The service trac system light just came on in my truck. I have had lights going on and off of the push button panel for a while now and have heard that some guys had issues with the panel and ended up having to replace it. not sure if this helps you but it may be a place to start.
