Trail readiness & pre trail checks
LagunaH1
Idaho
Let's start a thread to document what good, prudent steps one can take to ensure an H1 is ready for running trails.
I'll take the first stab:
Engine:
Oil level?
Oil change schedule adhered to?
Coolant level?
Transmission:
Fluid level?
Fluid change schedule adhered to?
Brakes:
Fluid level?
Pad wear / thickness?
Rotors healthy?
Tires:
Inspect thread for damage or stuck objects (including spare tire(s))
Ball joints:
Excessive play?
Steering:
Excessive play in idler / pittman arm?
CTIS:
Leaks? (Should be less than 2 - 3 pounds loss over 2 days)
Leaks:
Are there any leaks? If so, determine what's leaking and whether it's safe to operate
HUMMER INVESTMENTS
[o O IIIIIIII O o]
Black Hawk, SD
After the trip/Before:
Tires:
Have 1 person drive the truck and another person with a flashlight watching the tire. Roll forward slowly and let the person look for cracks on the outer part. Then have the driver roll backwards to double check. Now on the inner part of the tire you look under the truck and have the driver slowly go forward while you check the inner outer sidewall. Then roll backwards to double check:thumbs:
Kurt
Orange County, CA
I'd add another check:
I'd make sure the parking brake is working and adjusted correctly.
I'd worry about H1 owners who cheap out with the rear calipers, remove the parking brake and install the front calipers on the rear end. I bumped into that once.
Engine:
Oil level?
Coolant level?
If fuel filter hasn't been changed recently check it for remaining life.
Transmission:
Fluid level?
Brakes:
Fluid level?
Rotors healthy?
Check lines and calipers for leaks
Tires:
Inspect thread for damage or stuck objects (including spare tire(s))Check the sidewalls for cracks/splits
Ball joints:
Excessive play?
Steering:
Excessive play in idler / pittman arm? Check power steering fluid level
CTIS:
Leaks? (Should be less than 2 - 3 pounds loss over 2 days)Check the CTIS pump for proper operation
Leaks:
Tie rods: check boots and play
Half Shafts: check for wear, cracked or split boots
Transfer Case: Check fluid level, run the T case through the pattern and make sure their are no issue.
Geared hubs: check fluid level
Differentials: check fluid level
Headlight and offroad lights: check operation. Inspect bulbs for cracks/rock damage
H
