MaxPF
AGNTSA
- The dark side of the globe
Just highlights the DEX is just another way of making money out of a GM license (rather than real protection of the mechanicals)
Especially for poor bastards in cold environments that have had the factory fill of Dex VI turn to gelatin on them and wiped out their planetaries from lack of lube. Thank GM for not doing any proper testing on it before announcing it's the best stuff in the world and requiring it for 06-up. Basically, they let the customers do the real world testing for them :roll:
Of the Transynd or Delvac is one better that the other (or is it the common base PAO that makes them the same)
They both meet the same specs, so I'd go with whichever costs less.
Scratch the Penrite SYN ATF............. I just checked out the MSDS and it specifically says "Not Suitable for DEX VI application" although it meets the Drain Life & Friction requirements.
Probably for the same reason Transynd and Delvac don't technically meet the Dex VI requitements - their viscosity is a bit higher than the Dex VI spec. Personally, I feel that Dex VI is too thin, but I'm guessing it was partly (or mostly) done to reduce pump loss and get another 1/10th MPG. I don't buy the "shift quality" BS that GM spews - hot viscosity of Dex VI is around 6.0, while Dex III, Transynd, and presumably the Penrite are around 7.5. However, COLD viscosity of Dex VI is around 30, and the transmissions shift pretty much the same hot or cold. Tells me the viscosity requirement for shift performance is BS, otherwise they would shift radically different between hot and cold.
