H3T Unexpected oil pan leak
TAPDH3T
Texarkana, Texas
Soooo my warranty is almost up so I took my took to my local GM dealer to have it looked at and get a quick oil change..
I was told I had an oil leak in my oil pan which I have not seen any oil in the garage. They advised it was covered under the warranty but my lift was blocking the pan.. They stated it would be $450.00 to remove the lift and fix the issue..
I told Them I would fix it and picked up my truck.. Before I get under my truck and start tinkering around.. Has anyone else had this issue and what was the easiest way to resolve it??
ahhh...Yes I looked at the oil pan and lift kit crossmember design and it is a close fit. It may or may not come off with the lift kit on. Let me go outside and take a closer look and I will get back to you.
TAPDH3T
Texarkana, Texas
Yea until its on the ground I'm not to worried.. But if there is away around taking off the lift I want to know for the future lol
