Water sloshing
954paulo
ny
2007 h3 base
no Sunroof
So I noticed water on the passenger side. As I make right turns I hear sloshing noises and some water running onto the pass floor. I reached my hand up and under the dash and everything was wet!
I read someplace about the a/c drains being clogged. I haven't run the a/c yet this year. But we did just have a bad rain storm where my pass door was filled with water- I opened the drains on the bottom of the door and a few gallons poured out.
What's up with the dash water tho?
USMC_TOP
Muir Michigan
I just fixed my wet floorboard problem but mine was sunroof drain tubes disconnected. Maybe the non sunroof models have drains too? I would ask the dealer
Best4x4
Vidor, TX
It could be the HVAC drain or the front cowl drains where the fresh air intake is. If you pour water around your wiper arms and it doesn't hit the ground then that's most likely your problem.
Best4x4
Vidor, TX
I think you'd have to remove the plastic panel between the hood and windshield along with the two end caps. I had that clog up on my TJ and all I can say is ewwwwwww by the time I knew where it was clogged it was to late and all the muddy/sandy water dumped into my HVAC...
cbetts
NERD!!!
Rancho Palos Verdes, CA
Remember that the A/C runs when you have it on defroster so it still may be the drain there.
I have not seen any other leaks in mine so I don't know where any other troublespots will be located.
