Wet passenger front floorboard
Ryan212
Orlando
On my 2006 H3, after a very heavy rain I noticed water on the passenger side floorboard. I have searched and most point to sunroof drains. I do not have a sunroof. Any other common leak areas?
Thanks,
Ryan
The sealer/sealant/whatever mates the windshield to the body may be cracked and leaking. It could also be the bolt at the tip of the A pillar under the outside trim, that could be loose.
Babyjohn460
Burton, OH
Clear out your drains. Had the same exact issue when I first bought mine. There's a series of drains that need cleaned out every once in awhile. Like best4x4 said, it's likely your ac evap. core drain or the windshield cowl drain that's clogged. Kind of a design flaw if you wheel or live in wooded areas.
crwalkerasla
Corinth, MS
Has your truck ever been wrecked? My 06 has the same issue. I took it to the Chevrolet dealership for the fan resistor recall and had them check it out while they were in there. A body seam within the outside airwell along the base of the windshield had separated and they recommended taking it to a body shop. Or, you can just turn on the A/C recirculate cabin air & it closes the door to the outside airwell, and any rain. I pushed 1 button and no more leak.
Ryan212
Orlando
Thanks, I will check that out.
Truck has never been wrecked, but has likely had a little more torque on the frame than any other H3 out there.
Ryan
Sunroof drains. I just cleaned mine and opened up the end grommets...problem solved.
Took about a week to dry the carpet.
