zackcrum
- Corinth MS
So I took a 600 mile trip last night/today with no problems whatsoever. After parking my truck for a few hours this evening and coming back to it the 4wd controls were all going crazy. None of the indicator lights above the radio were working, not even the normal 4high indicator. The gauge cluster on the other hand was going crazy. It kept blinking service stab, service 4wd, and traction failed. Along with the traction control light inside the rpm circle staying on.
The truck drove fine, no difference at all. After about a mile I pulled over and pressed 4high. It would blink and go back off. The same with the other two. This was with the engine running in neutral. Then I cut the truck off and turned the ignition back on while in neutral. Once all the normal start up things happened it was the same story. I then put the truck in park, turned the ignition off again and started the truck. Back to normal it went. Has anyone had this problem? Is it something to worry about or maybe just a computer glitch? I've never had problems with my selector buttons in the past.
