H3 Wheel spacers?
backwoods
independence
Well i was having a discussion the other night with another H4O member about Spacers so here i am asking everyone pros, cons and personal opinion on running them ...
SWANK3T
Norman, OK
I'm thinking about this too I think 08solar had some good gouge about it if I remember right. I'm looking for or I think I'm looking for 1.5 to 2 inch and hub centric spacers.
Im running spacers with my lift kit. Depending on if your lifting it or not will help determine size u must go out vs. size u want to go out
MuDnYrI
Las Vegas
I like the way spacers make the truck look but I would be careful wheeling with them. I was at Rousch Creek a few years ago and on the way home after a good day of wheeling Jeromy's wheel came flying off on the Highway! As far as I know they determinded it to be the fault of the spacers vs wheeling
I remember that! A major difference and the reason I believe that happened is the type of spacer...
A spacer should with out a doubt be top quality! That means forged billet aluminum. A spacer that isnt as high of quality is a cast iron spacer, from what I remember (will have to double check) he used a cast iron spacer. These are prone to failing under heavy use like off roading, and if not torqued down properly they can crack.
The billet aluminum spacer isnt like that, they are much stronger and less prone to failure. My brother has been running his for thousands of miles with no issues on his JK. I personally believe if you have a quality spacer its just like running a backspaced rim. Just use billet aluminum and not cast! lol
idk the difference...lol All I know is that billet aluminum is good :)
Motorsport techs spacers are good quality IMHO but Hans3T had problems with them getting their stuff out on time, I didnt though. Just stay on top of it...
