Wheels that your running or are compatable with a 4" lift kit
SolidusJ
FT. Carson, CO
Jay,
Here are some pics of the tires.
Let me know what you think.
UGH those are the tires I want but they look great but I'm working on a tight time line but huge thanks for the offer :cheers:.
SolidusJ
FT. Carson, CO
17x9 American Eagles, -11 offset, fits the Rancho nicely.
Looks good but not what I've been wanting, now that I have no choice to get new wheels I mind as well get what I've been wanting. The wheels I want are 16X8 with 6 offset 4.5 backspacing and center bore is 108 mm. I want to order today to have my T back on the road next week.[h=1][/h]
You will need hub centric rings to keep your ride as smooth as possible! Personally I would recommend a 16x10 Wheel, really wide wheels make your tires look much wider/bigger and I've seen that in person, really nice!
Here's a really nice looking set of Toyota TRD wheels with 315/75R16 Duratracs with about 50% tread left on them. The wheels are 6x8, 6 on 5.5 lug pattern, 106.4 bore size that will fit on an H3/H3T. Also included is a set of four 1.5" wide Spider Trax wheel spacers. With the spacers, I would think that these will fit a Rancho-lifted H3/H3T. Price is down to $950 for everything.
These are not mine but I came across these on one of the forums that I frequent. I really like how these look and would consider getting these for my T if no one here gets them. They are located in Flagstaff, AZ but could be shipped to Phoenix, Prescott or Sedona area for another $85.00 give or take.
http://www.expeditionportal.com/for...acs-on-Black-TRD-Wheels-315-75R16-Spider-Trax
SolidusJ
FT. Carson, CO
I appreciate guys but I would like the wheel I posted up and stick with 285's. Just would like a go or no-go to buy them today.
offset and backspacing are similar. 4.5in backspacing with 33s on a 16 and 4.0 backspacing for 35s on 16s easy as that
SolidusJ
FT. Carson, CO
So the wheels that I posted up are good to go right? I also found out the center bore is 108 mm so they wouldn't be hub centric right?
They wont be hub centric, just lug centric. You may get slight vibrations even if your tires and wheels are perfectly balanced. Simple fix are hub rings (plastic or aluminum) that center your wheel when mounting
