Will these LED Bulbs-work on the H3 Tail-Brake-Stop-Backup-Reverse-Turn-Signal?
The H3 does use a 3157 bulb, so presumably a 3157 bulb from eBay will work. However, note that with turn signals a resistor may be required for LED bulbs to function properly.
deserth3
Conroe, TX
When I tried LEDs in my backup lights. The autodim in the rear view mirror stopped working.
For turn signals to not indicate you have a burned out bulb you will need a load resistor
Sent from my SM-G975U using Tapatalk
