wtb OEM GM Export Clear Turn Signal Lights
Check out this old thread and look at the pic. You can see the GM Parts seller - Ken Anderson's garage via Farnsworth Chevrolet - and one part number, 25791936
The other side is 25791937. Google them or just go to your favorite parts dealer and try ordering. Make sure you specify these are the export ones for Europe and South Africa.
H3ATH3N
Phoenix, AZ
Alrock - Ok - Got the export clear lenses... went to install with new switchback LEDs and now I'm finding the oem "connector?" that holds the bulb and connects to the lens casing doesn't fit. I'm assuming I now need to get "export" connectors - Schwartzy's links show possible option: Connector Part Information OEM: 16530672, Description: 3-Way F Lamp Socket (D-GY).
does this sound right? I'll try Reloader as well.....
