Nope, I have been running 305 COOPER ST MAXX and have over 100K miles on them with some tread left. Mostly highway miles at 45 psi. I Will be getting another set, but most likely going to 315's this next time.
I had Reloader's old set, the older directional ones. They were a loud tire and did their job, but it wasn't anything I'd buy again. I tend not to wear out tires with miles but instead with chunking of tread blocks, cupping (even though I always rotate) or punctures that force the purchase of 5 new tires.
I have the g003's. I got them in December and have about 5k miles on them. They still look new. I had them siped when they were installed and they did ok in the snow up in the mountains last winter. I have had them offroad a couple times but nothing extreme or anything. Just some forest roads. They are a little noisy. The most aggressive tires I had before these were Duratracs and I will say these are noisier then they were. With the sound insulation in the Hummer though it doesn't really matter. I can't say if I would buy them again until I have had them a little longer but they have performed well so far.
I just realized my current tires are the current Geolander MTs! I didn't even notice. I bought them off Reloader when he went to 37s. They are louder than other MTs and have a stiff sidewall (I believe they are load range E). I run 28 or 29 psi in them to soften the ride a bit, plus I noticed that at 30+ I was riding the center of the treads.
