Romanzz
- Denver, CO
It's too damn simple, just lightly pull off the rounding of the cluster cover and then removed the 4 bolts that hold in the cluster. The Colorado is only going to line up with the 2 bottom bolt holes but it'll stay in nice and tight. Also remove the NEG battery cable before removing the cluster harness. Post up pictures when you get it in!!!!!
Thanks bro. I appreciate the info and will definitely post pics once I get it back. Any specific tools you needed to remove the 4 bolts in the cluster?
