I went ahead and ordered the Bilstein 5100's and new 1/2 longer front bumpstops from Trail Duty, and hopefully I'll have it by this weekend, the price was AWESOME vs anyone else that had the 5100's for sale. I'm pretty sure my OEM shocks are worn out and I know for a fact I need the new extended front bumpstops as my front end dives pretty good during a stop. Interior wise I also ordered a brand new Colorado Extreme white faced gauge cluster that should be here tomorrow.
Next on the list is to get the front diff support bushing replaced. It's barely got 12K on it according to the records I found in the glove box, and it's already tearing apart. I'll just order the one listed on this forum and then send mine back as a core ASAP. Should I keep my original design diff crossmember or save a little $$ and just go with the newer style?
Then after that I'm thinking about that electric fan from PCM, but I just looked online and they've changed their design to include "flaps" which I don't really care for vs the original design I first saw. Does anyone here have the PCM electric fan on an Alpha? Here in TX my Alpha will start to run hot in slow traffic, or if I'm going 75MPH to 80MPH the temp gauge will sit just above half. How does it perform vs the stock clutch fan? Not worried about noise I just want good cooling performance. The only thing I don't like about the PCM setup is how the fan isn't centered. I would think that would cause hot spots where the air isn't getting pulled thru the radiator evenly.
Other than that I may swap out the aftermarket rear shackles I have for some shorter ones. Even with the front raised the rear sits a good 1.5 taller and my brake lines, and shock travel are almost already maxed out. Does anyone what the OEM shackle length is bolt to bolt? I'd like to see exactly how much longer my shackles are. If they're 1.5 to 2.0inches longer I'll replace them with some OEM or 3/4 extended ones. I want my H3 to be able to flex without ripping my ABS, brake lines, or damaging a shock mount.
