snoman48
- Poughkeepsie, NY
Hey gents,
So I've had the H3 for about 6 months now, and I've got a few questions that I figured I'd bundle together in one thread to avoid clogging up multiple areas.
Basics on the truck: 2008 H3 Base, I5 3.7L with manual tranny, 66xxx miles.
First question is for those with a manual; When I'm idling, say at a stop light or whatever, if I take my hand off of the shifter and let it sit, it starts to vibrate both visibly (understandably), but more so audibly. Unless I leave my hand on it, or stay in gear, it buzzes pretty good. Is this a common thing for you guys? Or is there something underneath I should look for to tighten up?
Secondly, for those with the Schwarttzy "Simply Aux-In" mod (the adapter that makes a aux in port as a jumper through the XM channel), I get a high pitched intereference noise when I use it, that follws engine RPM. I've tried changing out my aux cable to a higher grade / better shielded one, and using other devices, but it stays, leading me to believe that it's the adapter itself. Anyone found a fix for this?***UPDATE*** It's my charger for the ipod, not the adapter at all. Problem fixed until I get a better charger!
Lastly, my tires are shot, and I'm about to buy new ones. I'm keeping the OEM rims, but I'd like to go up in size. If my searches have been accurate, I can run 315 75/R16's with no problem correct? I have no suspension modifications done, or torsion bar crank performed; just bone stock. I'm choosing between BFG T/A KO's and General Grabber AT2's, as I can get them at essentially the same price.
Any and all input is appreciated, thanks for the help!
-Snoman
-Snoman
